Thetasigma
May just need to have the threads cleaned of grit and grease with some Isopropyl alcohol. Superlube works nice on the Tool for lube, but avoid Silicone Grease as I believe the o-rings are silicone and will shred since they will swell.
Also check the board in the head and make sure there isn't any grease shoved down there.
The light should turn on with a clicky and then can be used either as a twist or clicky.
