2 or 3-mode flashlight for 3x18650
zyrppa
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
Up to $100.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I intend to use Rechargeable cells based on less common formats (18650 Li-Ion).
I want a separate/stand-alone charger (this involves removing the batteries to charge)
I want search and rescue type illumination (800+ lumens).
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
30-50 yards/meters (I have a big backyard)
30-60 minutes (I have plenty of batteries just ready to be changed)
Very Important (Camping, Backpacking, Car Glove-box).
Any size switch will do.
I want a reverse clicky (For use with multi-mode/level lights).
I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
I don't care.
15) Water resistance
IPX4 (Splash resistant)
16) Storage conditions
In house (temperature/climate controlled environment)
I have Trustfire TR-3T6. It's good flashlight for me, but i hate that it has strobo&sos modes. I only need low/(med)/hi modes.
