DHart
Camping, long backpacking trips.... hmmmmm, you're going to need a light which will give you good throw, wide spill, high output and really low, low output, and long runtimes on low. A light with multiple output levels and versatile powering options. A light you can buy other battery size tubes and tailcap switch types for later.
Much as you don't want to spend more than $20. If you can possibly find your way to spend $60 and get a Quark AA, you will have a light with vastly greater utility and powering versatility than anything you can find for $20. Is the extra $40 a possibility? If it is, even as a bit of a stretch, I would say skip all the budget stuff and go directly to a Quark AA. You may not realize the wisdom of this now, but in time, it will be painfully obvious that a bit more investment in a really versatile, high quality light like the Quark which runs on 14500 li-ion, AA NiMH, AA lithium, AA alkaline... has a low of .2 lumens!, a very hot turbo output, five levels of brightness, a signal mode, SOS mode, and a super clean beam, excellent throw, wide spill, white tint.... all of these factors add up to far more value than the extra $40 you would spend. What else can you give up that really isn't that important to enable you to get a superb flashlight, rather than one that just gets you by?
You definitely need to consider this before closing the book on your decision.
