Good 1A boost driver (2 x NiMH)
FredM
Houston, TX
Going to use 2 D sized NiMH and curious what a good boost driver around 1000mA could use the 2.4 volts and drive a SSC P4.
Obviously looking for one that can suck the most juice out of the batteries and stay in regulation.
FredM
Houston, TX
Any single mode boards?
should have mentioned that first, not a huge fan of multi level etc.
How does it work though? Good runtime witht he low voltage batts?
eprom
Turkiye
+1 for DX Driver, I used lots of them Problemless
DX 3W 19-Mode Universal Regulated Circuit Board
EDIT:
if you want to make it ONE MODE follow this guide
https://www.candlepowerforums.com/threads/176180
FredM
Houston, TX
Wow thanks for that.
Nevermind, I found a good thread with much of your testing in and and am reading now.
Thanks!
Gunner12
Bay Area, CA
That I have no idea, you can probably post a question here or send dat2zap a PM.
My guess is that it auto adjusts the voltage to the load's needed voltage.
FredM
Houston, TX
I saw that but 1000mA is fine. How is the Vout determined? Is it stable or if not what varies it?
I don't need adjustable just want to know which LEDs it will work with.
