mangrovejack
- Joined
- Feb 7, 2007
- Messages
- 3
Hi,
I've been reading all the threads in the Dive Light section and am still confused with all the different options for building one of these lights.
Here are my requirements:
* Similar or better output than a 21w Salvo (Light Monkey) HID.
* Run on Lithium 18650 cells (I can build a battery pack in whatever voltage - 7.4, 11.1v etc - most likely 11.1v is needed?)
* Good run-times - around 4-6 hours
* Use as many oxycheq DIY parts as possible (reduce having to get stuff from everywhere - I'm in Australia so shipping from the US is always a bit expensive, so want to minimise shipping costs).
Looking around, I still can't figure out which LED to use. Which in turn means I don't know what light head to use - I don't want to go the maglite route - hence the reason for oxycheq parts as I like their lighthead.
I will be using a Delrin canister - this can be any size - but preferrably around 2.5"-3.5" maximum diameter and up to 10" in length maximum.
Anyone have any hints/tips as to what I need for my purposes?
Thanks.
Thanks.
