Agreed, must be headlights for LHD nations.
That's right, but boy does the terminology trip people up! "LHD" left-hand drive refers to the position of the steering wheel in the car. "RHT" right-hand traffic refers to the position of the car on the road. While most cars in RHT countries have LHD, this is not necessarily the case. The steering wheel position within the car doesn't matter to the headlights...the vehicle position on the road does. So it's better to keep things simple and understandable by referring to headlights by the side of the road they're for, as the lamp makers do.
As far as better, E codes are WAY better than 9004 headlights!!
Sorry, no, it's just not possible to make a generalization like this that's accurate. The beam focus of many 9004 headlights is quite sloppy, with more glare than is allowed by ECE regulations, but the peak intensity and therefore the seeing distance is often quite a bit higher/longer with 9004 versus H4 of the same size and shape. This is what I mean by "not necessarily better/worse". Pick a size/shape/level of technology/level of build and material quality, and the 9004 headlight will let you see a longer distance on low beam (but with high glare, narrow beam width, and uneven road surface illumination); the H4 will do a better job of controlling glare and will have wider, more even road surface illumination, but shorter seeing distance.
E code requirements ARE more stringent than ours.
For low beam, ECE headlight requirements are more stringent in terms of glare control (ECE allows 350 candela at the glare test point at 13.2v, US allows 1000 candela at 12.8v), less stringent in terms of minimum allowable intensity for seeing distance (ECE requires at least 5100cd at 0.6D/1.2R at 13.2v, US requires at least 10,000 candela at 0.5D/1.5R or 0.6D/1.3R at 12.8v), and less stringent on control of backscatter (self glare in bad weather - ECE allows up to 438 cd at 12v, US allows up to 125 cd at 12.8v). For high beam, ECE minimum intensity requirements at the center of the beam are less stringent (ECE requires at least 27,000 cd at 13.2v, US requires at least 40,000 cd at 12.8v) but the ECE spec allows about double the light at the center of the beam. On the other hand, US specs call for a wider high beam distribution, while ECE spec permits a narrower distribution. The US regulation is much stricter on reflector durability (corrosion resistance, solvent resistance, etc.). The ECE aim procedure during headlight approval testing is more stringent. Neither spec is strict enough on plastic-lens durability, but the ECE test is faster (days instead of years) and more readily repeatable.
So no, it cannot be said that either spec is categorically more stringent than the other.
It used to be E codes were illegal here because they pumped out too many CP
They were (and are) illegal in the US because the US does not recognize ECE regulations. Back in the '70s, the US code allowed only 37,500 candela per side of the vehicle in the center of the high beam pattern. Now the US figure is 75,000. The ECE figure has ranged from 225,000 to 300,000, though it's only recently with Xenon light sources that any actual main high beam headlamps have begun to approach the lower end of the ECE limits.
the E code cut off wasn't approved here (it is now), etc.
There's never been a prohibition on a European-style low beam cutoff in the US. All that was necessary was to make sure the various US beam test points were complied with. Since 1998, there has been a technical definition for two kinds of low-beam cutoff in the US regulation.
Remember, DOT stuck to sealed beams long after better stuff was available.
Sealed-beam construction makes a lot of sense for car headlights. The photometric performance of the American sealed beams wasn't great, but that's more an implementation issue than a concept problem; various firms in Europe and one American outfit produced halogen sealed beams in the early 1970s producing much more precisely focused beams than the typical US unit. They saw fairly wide use in England, but the H4 sealed beams (w/well-focused DOT beam pattern) GE produced at that time didn't get carried on in production very long.
It has always been spurious to claim either headlight regulation is overall better than the other. Have you seen the beam performance of a Hella H4 7" round ECE headlight (on an objective goniometer-generated plot, not a subjective "wow, lookit that sharp cutoff on the garage door!")? It's pathetic! Maximum intensity of about 11,000 candela; just plain not enough light. A GE H6024NH sealed beam of the same size and shape has a max intensity of about 25,000 candela. Less glare from the Hella. About the same amount of backscatter from both. You're not going to sit there and keep insisting the Hella light is better because it's an ECE light.
Both regs have way too much room for poor headlamps. If the Europeans and the Americans were both to tighten up their regs (lower maximum glare in America, lower backscatter in Europe, higher minimum low beam seeing light in Europe, higher maximum high beam seeing light in America, stricter plastic-lens requirements in both regs) the situation would be a lot happier.
