Misterbean
- Joined
- May 4, 2008
- Messages
- 57
i need a driver for a golf cart lighting system. The batteries are ran in series to power the golf cart and produce almost 37 volts. i don't want to run off of just one of the batteries and i don't want to run them parallel because they are already run in series and it would use too many wires and would clutter everything up. i am planning on running either two cree q5s or possible 2 ssc p4s. i want to push them between 800ma and 1000ma.
I need the varied voltage range because i don't want them to be blown when it is charging if the switch is flipped on. and i want them to be able to give light even if the batteries are fairly well drained. a bigger voltage range would be fine as long as it can handle what i put down.
