Every Feit CFL bulb that I've ever used burnt out in less than a year. Every Feit LED bulb that I've seen had pathetic output. Feit and Lights of America are brands I wouldn't even bother with.
I find the kelvin is a little low in my ~8w Sylvania and Ecosmart LED bulbs. They are not a bad replacement for a 40w bulb.
They are a perfect replacement/upgrade for a 25w incan.
They are 'just barely acceptable' in your typical simple ceiling 2bulbx60w fixture.
I will have to replace the ceiling fixtures with 3-bulb fixtures to utilize the Sylvania or Ecosmart.
Ecosmart:
http://www.homedepot.com/webapp/wcs...eDir=hdus&catalogId=10053&productId=202188260
Ecosmart specs: 429 lumen, 8.6w, CRI 85, 3032k
Ecosmart warnings: Not intended for use with emergency exit fixtures or emergency exit lights. Not for use where exposed directly to the weather or water. Not for use in totally enclosed recessed fixtures.
Sylvania specs: 350 lumen, 8w, vivid color CRI 82, 3000k
Sylvania(cheaper at BJs, Target, and Lowes):
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100670744
The LED heatsinks get too hot with either brand. We definitely need to consider thermal management when switching to LED.
My review. In a typical 2-bulb ceiling fixture, I would need to share the fixture with a single 14-18w CFL and one of the above LED bulbs. And, I would be 'picky' with the CFL kelvin. Love that homedepot has the various CFLs burning with comparison pictures.
My Kill-a-watt meter says(10ft cord going to the lights):
6.9w for the Ecosmart
6.2w for the Sylvania
21.7w for a 23w LVD bulb
http://www.superlumination.com/lvdbulbs/images/lvd_small_dims_wm.jpg
58.8w for 60w extralife incan
If you stare at the Sylvania bulb, you can see the 6 LED's hidden in the globe which is definitely has a better 'frosting' that distributes the lighting around the globe evenly.
The Ecosmart bulb has 'less' frosting so its a little brighter and a tad more glare if you look at it. You can't really tell how many LEDs it has.
IMO, equivalents in enclosed fixtures:
2x 60 want incan's
2x 13w LVD's
2x 15w CFL's
3x 8w LED's
1x 8w LED + 1 13w LVD or 15w CFL
In an open fixture, you should be able to replace a 60w incan with either of the 8w LED bulbs. You might have to aim them for visual preference compared to the better flood of an incan or CFL.
For comparison, typical enclosed fixture:
http://www.homedepot.com/catalog/productImages/300/8d/8d1cb29b-c1f7-4376-a307-7d0eb8ec3b03_300.jpg
http://i.walmartimages.com/i/mp/MP/10/00/02/18/MP10000218173_P255045_215X215.jpg
Open fixture(tree lamp) almost perfect for 3x Sylvania/Ecosmart LED:
http://i.walmartimages.com/i/mp/MP/10/00/00/49/MP10000049357_P255045_500X500.jpg
If they made Ecosmart or Sylvania in 4k, 4.5k, or 5k, with an extra 40-100lm, I'd buy a dozen.
