I got a hold of a Surefire A2 courtesy of Tony (Chop) and picked it apart and this is what I found under the hood. I decided to post it since it may be of interest to anyone who is contemplating a mod for this thing, or just maybe curious about the stuff under the hood. The A2 is a marvel mechanically and electrically. Surefire did an excellent job in the design of this light.
Let's begin with construction. There has been posts in the past stating that there is an inner sleeve that acts as a separate electrical path for the purpose of the low beam mode. This in fact is not true. While there appears to be a sleeve, it is nothing more than an insert whose purpose is to provide a more precise contact point for the two stage tail cap. It is electrically common to the body of the light. Why this level of precision was needed, I don't know.
The low beam is facilitated by the use of a current limiting resistor in the tail cap, similar to the L1. I don't have an L1 on hand to do a side by side comparison but I wouldn't be surprised if the tail cap is the same. The resistor values are about 10 ohms on both units. When you activate the first stage (low beam), the 10 ohm resistor is in series with the battery. This effectively limits the current going to the regulator located at the top of the body, below the head. I confirmed this by removing the tail cap and putting a 10 ohm resistor between the (-) terminal of the battery and the body of the light. The LED lights up with the same brightness using the tail cap switch. I then shorted the (-) terminal of the battery to the body of the light and lo and behold, the incandescent lit up. This confirms the operation of the tail switch.
Next, I looked at how power is allocated between the LEDs and incandescent lamp in the low/high beam switching scheme. If you look at the way the head is wired up, the incandescent is in parallel with the LED assembly. That means when the LED assembly is receiving power, the incandescent is also receiving power. In the low beam mode, the power to the incandescent lamp is below its threshold of turn on. The LED's however, are perfectly happy with the low current being supplied to them and consequently turns on. Now if you activate the high beam mode shorting past the current limiting resistor in the tail, the power to the lamp increases to turn it on. The LED's are also receiving power but there are current limiting resistors in the LED assembly as well to prevent them from being overdriven excessively in the high beam mode. If this theory is correct, then the LED's should be slightly brighter when the high beam mode is enabled. I removed the incandescent lamp and placed the head back on the body and actuated the low and high beams and confirmed my theory. The LED's do get brighter in the high beam mode—and it is noticeable.
Finally, some electrical measurements from all you geeks out there (no offense, I'm included in that remark /ubbthreads/images/graemlins/grin.gif )
From the batteries (using my own fresh 123's since I didn't know how fresh the supplied batteries were)
Current = 1.3A
Voltage = 5.7V
Power from source = 7.4 Watts
To the incandescent lamp:
Current = 1A
Voltage = 3V
Power to the Load = 3W
Before drawing conclusions here, bear in mind that I don't know if my voltmeter is an RMS meter (I doubt it is) so the measurements to the lamp may be in error. This is an important point since I believe the lamp is being pulse-width modulated. Therefore, the power measurement of the lamp may be in error. Regardless of the efficiency, this is one impressive light. It's comparable in output to a Pila 3.7V lamp (which Pila rates at 80 Lumens), with a slightly whiter beam, but you get this level of light from the A2 during its entire run in regulation whereas the Pila's turn yellow after about 10 minutes. The only drawback, and it is a big one for me, is the very short run times reported. I haven't confirmed this, and I'd rather do it on a light that I own rather than burn up time on Chop's lamp assembly.
Depending on the availability of this light for me to play with, I may put this thing on an oscilloscope and look at some waveforms at the lamp terminals. I don't want to hold on to it too long since it was very graciously lent to me by Chop and I'd like to return it to him as soon as his KL1 mods are done. Unless I decide to buy it from him /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif hehe.
CM
Current = 1.3A
Voltage = 5.7V
Current = 1A
Voltage = 3V
CM
