cat
RichS, which reflector are you using with your 2C 5761?
I am using the FM MOP Cam/Camless reflector (w/out the cam installed).RichS, which reflector are you using with your 2C 5761?
I'm not sure I understand the benefit of this. Forgive my ignorance, but wouldn't this make the spot nice and smooth but reduce the throw? I would think you would want throw if you are going with a SMO reflector, and since a hotspot is already very intense wouldn't it be more beneficial to smooth out the spill area? It sounds very intriging, but I'm not seeing the benefits.Northern Lights favourite, what I did, use a smooth reflector and frost the bottom part of the 5761 bulb.
Thanks, that does help. I can see how this would smooth out the hotspot, but I am thinking it would also somewhat reduce throw.Find some Northern Lights posts on the 5761. He needs throw, so he uses smooth reflectors, and frosts the lower part of the bulb up to the level of the filament to reduce the "batwing" type artefacts. So, minimal light lost from the frosting, because the front of the bulb is not frosted.
[I think that doesn't sound very clear but find his posts and you'll see.]
Mine still has "batwings", though. I'm trying to decide between a HS and a MS reflector, before they're sold out. I do have a MOP, though, that I haven't tried yet.
