I have a couple torches that are set up to run 3-4 primaries or 2 lithium rechargeable. I like the idea of running a 2 17500 or even 18650 as it will significantly lengthen the run time but these will see use in a high reliability application along with frequently potential sudden impacts. I know 2xCR123 set ups have tolerated this for many years so I'm going to assume running 3 won't be an issue. Not sure why 4 would be problematic either.
Other than the usual concerns running li-ion in series any concerns running a 2s configuration using high quality cells?
