2x AAA Minimag hotwire
Juggernaut
A place in need of light.
In my search for a bright 2x AAA Minimag upgrade I thought that simply installing the 29 lumen "1 lithium twin task xenon bulb" would be the best way to go, but then I started thinking whether or not my newest idea would work, how about using the 2 lithium bulb version and running it on 2x AW 10440 lithium batteries, would the bulb handle 7.2 volts over it's 6 volt rating, and would the batteries be capable of delivering enough amps to power the bulb "would it drop under amp sag?" If I go this rout I really don't care about run time "as long as it works for at least 10min." So what do you guys think. Oh and as a note in the earlier 3 volt bulb mod I would use Energizer lithiums.
Thanks for suggestions:thumbsup:
