Outdoors Fanatic
What's up, my fellow Incandescent lovers!
I am immensely happy to report you, that according to my 'un-scientific' tests, it is safe to run the MN21 on IMR cells as long as you don't go higher than size 18500. No instaflash so far--even on topped-hot-off-the charger cells (I've repeated this test countless times on healthy IMR cells).
Apparently, the voltage sag is enough to prevent a dangerous overdriving (either that, or my MN21 is one tough SOB). Eventhough there is some voltage sagging, it is noticeably brighter and whiter than either on primaries or on 2x AW18650 LiCo cells.
Not to mention and it delivers a very flat discharge curve. What a great setup! This makes a great Winter "Pocket Rocket". 2x18500 form-factor and the KT2 is compact enough for any cold weather jacket. Brighter, lighter and much more compact than a Mag ROP 2C, you can't go wrong with this setup.
Cheers.
lovecpf
Cheers.
lovecpf
