2x18650 3-Cree light.
MikeV
Since you mention "high quality", you might want to checkout Thunders from Wolf-eyes.
Alan
Thanks all.
I think I am going to go with the RC-T5.
That Wolf Eyes looks nice but I can't find a drop-in for it.
Here is what I am looking at.
http://www.dealextreme.com/details.dx/sku.10451
http://www.dealextreme.com/details.dx/sku.5776
http://www.dealextreme.com/details.dx/sku.6105
Is all of this stuff compatible?
I know that the batterys and the charger are cheap, I will upgrade as funds allow.
Thanks.
Mike.
It's ok. Grey Trusfires have 15% more capacity than AWs. If I were you, I'd get 10452 instead of 10451. It looks much better in grey.
these are a tiny bit smaller than the 18650's you listed, so they'll fit in more lights (good!)
Personally, I'd go with this charger- it can charge multiple battery types and has a good reputation on CPF.
These are also unprotected.
It takes 6 hours to charge 18650 cell. Many people don't need CR123 sized batteries (since they're expensive and inefficient).
My recommendation would be to wait for a nice P7 C bin light. It should put out 600 lumens or so...
Hi Matt,
I've been waiting for LumaPower to announce a big light! I wonder if this is it.:grin2:
" protected is just a name'???? Beg to differ, but those ARE protected!! I have several of them. Also I don`t know where your getting this info but those 1251 chargers charge a protected cell in about 2 hours not 6, I also have the charger and they work great as do the 18650`s
I can assure you they're protected. I have 2x of all trustfire and ultrafire protected/nonprotected 18650's from DX
Did you find protection PCB?
There must be something wrong with your charger. "Charging current is 450mA per channel" which means that in 2hrs your 18650 was charged to 800mAh (usually it takes about 6 hours to charge 2,2Ah cell).
lithium cells don't fully charge in significantly under 3 hours. Ever.
Even if you increase the charging current, you get stung when it switches to the constant voltage phase- you decrease the CC time, but increase the CV time. Net result is still about 3 hours. However, the advantage of higher charging currents is that if you pull a cell early, it has more charge than on a lower current.
O/k you caught me in a little white lie,I usually drop my batteries in when the voltage is down to 3.8, it then charges to 4.2 in about 2.5 -3 hours not 6
