Trailbasher
Hi…I have been through a ton of great info and require some help.
I have the following batteries and charger which show the technical specs:
http://www.batteryjunction.com/rc390reliba.html
"Internal voltage regulators. Initial cell voltage of 3.6V switches to 3-3.2V within 12ms"
When charged the batteries are approx 4.2 V. I used them in a jetbeam III-M
for 10 minutes continuously (5 low, 5 high), with some measurable heat coming of the flashlight body. The measured voltage after was 4.06 and 4.1 V.
Not understanding the technical specs of the battery; does the voltage regulation cut down the voltage while in use only? Or at all?
Bottom line is "are these voltage readings normal?"
I will eventually go to the 18650 rechargeable set up and use the rcr123's in a single cell flashlight.
Thanks in advance for all comments.
Mike
Mike
