Finally I got a flashlight might have HID light effect. It is a 3 * MCE total 30W LED flashlight. A new design MCE flashlight made in China. They now foucs on develop on MCE flashlight. This is one of their high end product.
Features:
CREE Quad die MCE/M-WC + MCE/M-WH + MCE/J-7B
Constant Current Regulation Output
Housing Material : Aircraft Grade Aluminum
Copper seat for MCE:
Tailor made copper seat for Superior Conductivity between MCE and outer radiator fin.
Copper Contacts for Superior Conductivity and Durability
Aluminum Optical Reflector with polished finish
Battery Options: 4*18650, 6*18650, 2*32600, 2*32650 Li-ion Rechargeables or 6*AA battery
All inOne Digital Rotary Switch with Off Position and Tactical Strobe
Default mode: Maximum brightness (100%) -> 30% brightness ->lowest brightness (5%)
Concealed mode: Strobe -> SOS-> Continue tunning level (5-100%)
Power tuning method : 3.9KHz PWM. However I can't discovered PWM on ANY power level.(pointing it into a fan)
Working voltage: 5.5v to 15V
LED lens:
Custom lens to enhance the foucs of MCE. Hence the shooting power can beat Q5 light. It also assist heat conduction to aluminum base.
Dimensions:
Head - 108mm
Body - 43mm
Tail cover - 50mm
Length - 250mm
Included accessories:
Spare o-ring
AA Battery Magazine Holder x 2, efficiently loads AA batteries compatible with 32600 tray
Copper spring fitter.
Optional:
Light Orange-Peel Reflector.
Initial Impressions:
It is huge guy. The head is similar to my 35W HID. It is also heavy. Even no battery is installed, it weight. The thickness aluminum boby make a duty belt light. The light is HAIII hard anodized in green. From my veiw point it's my best surface light.
Cons.
You must use both hand to rotate the head to switch it.
Current draw:
All current draw measurements were done with a 80% full 2*32600 Li Cell. (measurements of draws from the batteries) These batteries are in series so the driver is getting 7.2 to 8.4 volts.
Low - 0.07A
Med - 0.86A
High - 3.36A
Front from left to right M8X, Tiablo A9, M1X 2AA, UltraFire 502B, M8X, M2X, M1X
Back left WA1185, right 50mm MCE/K
Briefing on these flashlights
Mzzlg (LoChow) M8X: a low-price shooting light made by LoChow with plastic Reflector. It is direct drive by 2 18650 FeLi Cell. MCE/J-7B is configured to 2p2s
Tiablo A9: a famous shooting light, Q5
LoChow M1X 2AA: Q3
502B: General purpose light Q5-WH, 1A circuit.
M8X: Q5-WC drive by 3*7135 circuit, 1A.
M2X: Q4-5B drive by LT3454 circuit,800mA
M1X: MCE/M direct drive by 14500 Li Cell. MCE/M is configured to 4p.
WA1185: 9.6V35W
50mm: 2*32600 Li cell drive by AX2002 circuit,1.4A. MCE/K is configured to 2p2s
1 Meter Beamshots . very bright hot-spot, and amazing flood beam.
35 Meter Beamshots
Outdoor Beamshots : In order allow A9 to show up properly, 3*MCE is slightly overexposed.
camera exposure:
Aperture: 5.6
Exposure: 1 / 2 seconds
ISO-1600
Focal length: 27
White balance: lighting
(the exposure was set the same each time)
3*MCE
M1X MCE/M 14500
502B
A9
M2X Q4-5B
120 Meter Beamshots:
I only upload the light which can product a reasonable hotspot on the photo.
camera exposure:
Aperture: 5.6
Exposure: 1 seconds
ISO-1600
Focal length: 82
120M 3*MCE
120M 3*MCE(medium)
120M left:3*MCE right:A9
120M left:3*MCE right:HID
120M left:3*MCE right:M8X
120M 左:3*MCE right:WA1185
Conclusions:
It is the most powerful LEDs light I even see. It easily beat mime Q5, MCE & 35W 9.6v(incandescent) lights. Only 35W HID handhold can beat it.
Features:
LED lens:
Dimensions:
Head - 108mm
Body - 43mm
Tail cover - 50mm
Length - 250mm
Spare o-ring
Optional:
Cons.
Current draw:
Low - 0.07A
Med - 0.86A
High - 3.36A
LoChow M1X 2AA: Q3
WA1185: 9.6V35W
35 Meter Beamshots
camera exposure:
Aperture: 5.6
ISO-1600
Focal length: 27
3*MCE
M1X MCE/M 14500
502B
A9
M2X Q4-5B
camera exposure:
Aperture: 5.6
Exposure: 1 seconds
ISO-1600
Focal length: 82
120M 3*MCE
120M 3*MCE(medium)
Conclusions:
