700nm
I soldered 5-2V red LED's in parallel to a 10 ohm resistor and did the same for 5-2 V 20 mA yellow LED's. Then soldered 5-3V blue LED's together in parallel. When I connect blue and red/yellow to the same 3 V battery(2-1.5 V alkaline batteries) the blue LED's receives very little power and is very dim. I didn't connect the blue LED's to a resistor and it's labelled 3 V 20 mA.
Would the LED's be mislabelled? If i connect the red and yellow LED's to the same battery it both wouldn't dim much. Would it make it maximum brightness if I connect more batteries in parallel?
if you add a slightly different say 9 ohm and a 10 ohm resistor to each LED's would it be significantly dimmer for the one with 10 ohm?
