I have a lantern that can be powered by 4 D-cell batteries or by plugging it into a 12v accessory socket. I have two re-chargeable jumper boxes that can be used to jump off a car, which also have a 12v accessory socket on them. I keep one in the car and one in the house.
I bought the lantern to have in case of a power outage so that I can plug it into the jumper box and it should power the light for days. So far we've only had three power outages since I bought it. The first time it went out, it was only out for about 15 minutes, so I hardly got to use it. The second time the power went out, it was out for several hours. The lantern worked perfect. The lantern has a 10ft cord, so I set the power box at the foot of the bed, and placed the lantern on the bedside table. I laid in the bed and read a book for a couple of hours. The power came on shortly after I turned the lantern off to go to sleep.
A few days ago the power went out again. I plugged the lantern up and it came on for a few seconds then went out. It turned out to be a blown bulb. I have a 2 D-cell LED Maglite, but it also came with a krypton bulb. The lantern's bulb looked like it was the same size as the Maglite's bulb, so I fetched the bulb from the bottom of my Maglite. It fit, and worked fine in the lantern, though the power was only out for about half an hour.
The bulb on the lantern says 4.8v 0.75amp (it also says that on the bottom of the lantern), but the Maglite's bulb only says Maglite 2-D or something like that. I went to get a replacement bulb a couple of days ago because we were expecting some bad storms. I forgot the voltage but I remembered the 0.75amp part, so I bought the only 0.75amp bulb I saw. It was labeled as a replacement for a 3 D-Cell Maglite and was rated 3.6v 0.75amp.
I didn't feel like going back to exchange it, and luckily our power didn't go out. I went back today to return the bulbs and get the right one. I found the right bulb, it was labeled 6v Lantern 4.8v 0.75amp. I also found an LED "bulb" that says it will replace any bulb in any C or D cell flash light up to 9 cells, so I figured I'd give that a shot too.
When I got home I checked each bulb in the lantern. I turned off the lights and turned the lantern on with the 2 D-cell Maglite bulb still in it. It was pretty bright, but it had a blueish color to it. I put in the 4.8v 0.75amp bulb. I appears to only be slightly brighter, but it gives off a more natural white/yellow color. The LED bulb was not as bright, and had that blue/white LED color. I put the 4.8v bulb back in, and I figure I'll keep the LED handy in case the krypton bulb blows again.
Now here's the part I'm confused about. If it uses 4 D-cell batteries, that is 6v, but I plugged it into the 12v DC power box and used a multi-meter to test the voltage going to the bulb and it is putting 12v into the bulb, it doesn't step it down to 6v. What is that doing to the 4.8v bulb by pumping 12v of power into it?
