Woods Walker
The Wood is cut, The Bacon is cooked, Now it’s tim
I believe the head is glued on so unlike a normal quark that's a no go aka lego.
Mine is not glued... at least not very well
I tried it last night with 2 eneloop cells in a regular quark 2AA tube, and it worked fine (albeit a little less play than I'd prefer). I also tried a 2L tube with an olight 16340 and a spacer/dummy, but the tailcap still needed to be loosened.
Thanks WW! That's exactly the 16650 I was considering... so you're saying that the tailcap still needs to be backed off a touch while using that battery? In that case I may try filing down one of my dummy CR123 spacers...
Yes though I wonder if naked lithium ion act the same as reducing the length. I don't have any unprotected batteries in either size. On a side note check out your head to see if the golden ring fell out like mine did. edit to say an unprotected lithium ion should be shorter than protected. Given the low voltage warning over discharging seems unlikely.
I don't think it is worth the time to try and modify this light to work with lithium ion...
Did your brass ring have a split in it like mine or was it a full circle.
It has a small gap in it, just like yours
And a mini bolt for 27$ [emoji4]
Ok then it appears nothing broken. Just part of the design. Still I don't like parts falling out of flashlights, guns or knives.![]()
