smallhagrid
I work in the tech field and every so often I'll come into UPSs that
need changing out, but that are not burned out or dead.
Many times their batteries are not great, and some of the older units
are literally too slow at switching for faster PCs and otherwise fine.
One of these 'rejects' is literally near my bed and connected to a
reading light as it's main power source - when the power from the
street is working normally, no big deal - but when it is out I've got
enough power for my lighting to last for more hours than I've ever
needed to use it - I've never run it out.
So:
A couple of things about these units that perhaps may help folks
who have not been exposed to them - assuming to start that you
know what a UPS is and/or does...
Many UPSs use 12V gel cell lead-acid batteries; some use a pair of
them and in cheapie ones they use other goofy combos like 2 x 6V.
I'll use the APC BK650 as my example because it is my all-time most
favored UPS and has a single 12V battery...
Here are some ways to get very useful and practically infinite service
out of these 'rejects' if you should be lucky enough to get them:
Simply re-use them as backup power for low wattage gadgets with
memories or clocks - never have to reset a VCR clock again !
(Adding a nice Belkin single outlet surge protector at the wall with
an 'older' UPS will provide fantastically stable power for a stereo...)
If you are even braver, skin the old thing and being VERY careful of
possibly charged large-ish caps and such, you will find they are also
WAY easy to use for domestic backup power for lighting and such.
I use both these ideas myself and they work very well.
1. Connect an automotive cig. lighter outlet to the battery leads
on a cord and emplace it conveniently to have 12VDC for gadgets
when using them indoors.
2. For extra-long backup power, make use of a better UPS's great
internal battery charger/conditioner and after removing it's own
battery, connect an external, bigger battery.
My method of doing this indoors safely is to run SJO cord from the
UPS to a hidden place where I put 1 or 2 garden tractor batteries in
a dishpan.
This will either provide LOTS of 12VDC for gadgets or longer backup
power for anything the UPS powers with it's 120VAC inverter.
And for the naysayers - I've never had a hydrogen emission problem
because this setup is neither charged nor discharged rapidly; it is a
good source for lighting or gadgets - NOT for arc welding !!!
Lastly - most UPSs have an obvious piezo element which drives you
bonkers if it is left on when the power is out - it is utterly simple to
lobotomize these by just crushing off their tops and disposing of the
crumbled guts - they are not missed and the UPS will usually go on
doing just what it was otherwise made to do, but in blessed silence.
Best Wishes.
mark
So:
a dishpan.
Best Wishes.
mark
