Sure, if you auto store carries these. Match up the front side of the metal flanges on both bulbs and then see how close the center point of the arc chambers are. I shimmed mine .075 IIRC. So if the replacement bulb arc chamber is the same or up to 1/32" further away from the flange, it will probably work. If it's shorter or closer the the flange, it will not work. Another way of saying this is usually, you need to move the arc chamber back towards the back of the reflector to get the tightest beam. But you can't easily move it back more than a typical flat washer's worth.
