and the search goes on....
while the ebay site doesn't have much useful info, they do provide a useful link:
http://www.nbglin.com/dc.htm
and the "LM2577" on the boost converter IC tells you that this is one of National Semiconductor's early "Simple Switchers". Nice, well behaved parts.
You can dig up the datasheet too:
http://www.national.com/ds/LM/LM1577.pdf
The datasheet tells you what the device can do, for the most part. In your case, I think the biggest issue is the power that you are wanting to convert. It sounds like you want to convert about 100 watts of power (two of the leds, each of which is drawing about 50 watts).
The problem is that the switch transistor can handle up to 3 amps. This is the current that the converter will draw from the 12v supply. Ignoring the current ripple, this means that it will only convert 36 watts of power, and not the desired 100 watts. Heck, it won't even drive one of the Bridgelux leds that you are looking at.
There are other limiting factors too, such as the current rating for the inductor and flyback diode. Only the factory in China knows what parts are used on the circuit board.
So.... unless I've overlooked something, this is not the converter for your application.
OTOH, you could always run one or two of these in parallel to get the desired output current. You'd need to run a small resistance between each converter output and the common load (or led) in order to get the converters to share the load properly.
regards,
Steve K.
