While doing Xnova AA vs Ultra-G, ArcAAA, Dorcy 1AAA -
I noted the very strong stray side emission of the Xnova AA
with strong "spikes" at approx the 150/30deg markings on the protractor.
If the light is held close to a surface a noticable halo/ring of light can be seen
This of course is not all that uncommon to 5mm domed LEDs -
what was surprising was that the 5 LEDs are completely recessed in the (holed) head (one cannot feel them when pressing against the head) and there is even a slight lip/hood to the front bezel
Other LED lights also exhibit this stray side emission and therefore the halo/ring of light
Of course what's surprising here is that the bare exposed LED of the Photon 2 seems to give less side stray emissions and hence the halo/ring of light than the well recessed LED of the 20 for $20 LEDs from CountyComm.
Even in the image of the coin-cell lights where I left them switched on - one can just make out those side-spikes on all three lights - despite 2 of the lights had well recessed LEDs
My speculation/guess is that these side stray emissions are due to the internal refraction/reflection in the clear plastic dome - and the light emanates from near the tip of the dome so any recess needs to be quite deep to mask off the stray side emissions.
The Nichia(?) LED used in the Photon 2 shows less severe stray side emissions than the (probably Chinese) LEDs used in the 20 for $20 and the Xnova AA - and by the characteristics and tint I would hazard a pure guess that these may be the same LEDs.
Just as an experiment I wanted to see how much masking/hooding it would take to eliminate the stray side emission of the Xnova AA.
I simply rolled some (heavy gauge) paper (a leaflet) snugly around the light to form a tube, and secured it with a rubberband
This allowed me to slide the light in and out in the tube to vary the hood/masking effect
fully masked/hooded to eliminate the stray side emission, hence halo/ring of light (at depth - about 5/16" or 8mm)
Not enough mask/hooding - but shows an interesting clover-like effect (at depth about 5/32" or 4mm)
a sort of compromise - perhaps "optimum" depth of about 1/4" or 6mm
Please let me know what you think -
and perhaps your thoughts on the causes of these stray side emissions?
