I completed an 8 day (192 hr) test of 5mm LEDs driven at 30ma. Regardless of their rated current, I consider maximum current to be 20ma, so I am over driving them by 10ma. In fact, one LED rated at 30ma showed notable change.
Results: (column 1 is over drive, column 2 is control - not driven and pre matched before test)
A. Asia Engineer's (ebay) 13,000 mcd white. These LEDs have a greenish blue tinge and faded very little.
B. Superbright LEDs 18,000mcd 15 Deg white. Faded a bit but had a notable purple shift.
C. Sylvania X-mas light string hacked flange-less wide angle white LED is only 3mm, but these are the brightest and fading was non existent (or very slight). The clear winner!
D. Warm white hacked from string purchased at Menards. These are nice and bright WW, but suffer significant fade in this test.
(Not Shown) From ebay seller cece718. These had a blueish green tinge and it faded. Not nearly as bad as the WW LED, but quite noticeable. Another batch from the same seller is more of a purplish tinge and faded the same. (I tested several from each batch for color. Each batch consistent.
Conclusion. I don't have the equipment to post actual numbers, but all I really need to see is the visible fade. The camera actually shows it more than by eye.
I was very surprised to see a x-mas string 3mm LED show no fading. These are also brighter than any of the others. I expected a small 3mm LED to fade faster due to lower thermal dissipation. I guess sylvania puts good quality LEDs in their strings. Recommended!
Next I'm going to turn up the heat
. They are at 40mm to make them suffer.
