I have recovered the following data from Google's cache manually.
Please post any errors and corrections in a new post below.
The format is:
Date, time, old postcount#, poster;
post data
I will try to fix the CPF links in the next 2 weeks or until I give up in frustration. Can not do that and verify with CPF down.
11-20-2010 03:36 PM #16 liteheaded
kethd said:
What exactly is "remote phosphorous technology"?
They put blue LEDs inside the bulb and the yellow phosphor converts it to white light.
Why do this instead of just using white LEDs? It gives a more even distribution of the light.
Aren't blue LEDs cheaper than white LEDs? See this article on the invention of white LED's. Other sources claim another inventor accomplished this five years earlier.
http://www.msnbc.msn.com/id/9777070/ns/technology_and_science-science
11-20-2010 04:22 PM #17 MikeAusC
Don't you just love gems from some journalists "LEDs don't emit heat, so they're also more energy efficient."
Mike R
11-21-2010 01:38 PM #18 liteheaded
He's thinking of the wimpy indicator LEDs in electronics. I'm not sure if the well-known "blinking twelve" is lit by LEDs.
12-22-2010 04:52 PM #19 fnj
kethd said:
The DOE rules require "Energy consumption of less than 10 watts"
What "rules" are these?
12-22-2010 09:54 PM #20 yuandrew
FNJ said:
That was one of the requirements in the "L" prize book
http://www.lightingprize.org/pdfs/LPrize-Revision1.pdf
(go to page 8 of 18 and look under product category requirements for the 60 watt incandescent replacement)
12-24-2010 05:16 PM #21 blasterman
I'm guessing, but probably because the larger dome of remote phosphors gives a softer distrubution of light. Why in blazes would you want a single point LED blazing at 800 lumens and them have to lose efficiency diffusing it?
Next guess; the remote phosphors are off die and hence aren't getting baked at on die temps.
