6v bi pib bulb needed
Rogue_monkey
Ontario, Can
I have an old cat eye bike like that I would like to make brighter by changing the bulb. It is a 6v light that can take 4D's in a holder and then powers a medium sized bi pin bulb.
Does anyone know what bulb would make a good replacment lamp for this light?
the bulb in it now is twice to three times the size of a AA mag bulb for reference.
You Should overdrive it and us a AW6V or a 5761 :D Both Nice bright blubs :D
Problem with the 5761 is that 4 alkaline Ds won't come close to being able to drive it with any efficiency.
You have to figure out what batteries you can use first. If you can fit 5 ni-mh sub-Cs in there, it'll drive the 30w bulb with ease, whlie giving you about 1/2 hour to 40 minutes runtime. This may not be enough on a bike
I'd suggest a generic 10w (2000 hr halogen) G4 bi-pin halogen bulbs overdriven at 7.2V - 8.4V, using ni-mh AAs. This will give you about 2 hours of operation on 6 2500mah AAs, or over 4 hours on 12.
Something like this would also work w/o over-driving:
http://www.bulbconnection.com/ViewItem/bcrw/itmid/819/oc/ESA%2FFHD/item.html
But on any long life bulbs (200 hr +) you'll need atleast 7.2V to make decent lumens.
