I have a couple of deep cycle, 75AH batteries (look like car batteries) that each use a 40W solar panel and charge controller (to prevent overcharging). I know that they will arc if I accidentally short the terminals, so they've got some serious push, and can be drained to like 30% or lower. I think they are lead acid.
Anyway, can someone make a recommendation on which model or type of bulb would be recommended with them?
I want to do a 3-bulb setup, each with it's own reflector much like some of the WolfEyes 3-bulb setups. However, I want to experiement with making a refractive flashlight. It would be handheld, but would have a power cord to the battery and possible circuitry. I will use 1 battery.
I need to make sure that this below is feasible:
The refractive setup would be like a reverse refractive telescope. The 3 bulbs are focused onto a central reflector, and then reflected again off a larger reflector that surrounds the bulbs, and then projected outward. Two lenses could then collimate the beam if separated by their focal-lengths.
I wanted to do a diagram in Bryce, but didn't get to last night. I would like to do a beam of heat and light, so I'm thinking halogens. I can put cooling in the handheld unit, such as liquid cooling that would run behind the reflectors.
