3rd_shift
The light came from Walmart today at a hefty 1,899 cents. /ubbthreads/images/graemlins/ooo.gif
($18.99) /ubbthreads/images/graemlins/wink.gif
Here is the exploded view of the light.
No thermal paste came with the Luxeon1 star. /ubbthreads/images/graemlins/confused.gif
That will be fixed in a jiffy. /ubbthreads/images/graemlins/naughty.gif
Disregard that sorry SX1L as I decided not to use it after all. /ubbthreads/images/graemlins/crazy.gif
Let's see here....800mah, or 1800mah? /ubbthreads/images/graemlins/thinking.gif
Looks like there is room in that light for an 18650 doesn't it. /ubbthreads/images/graemlins/wink.gif
Took a dremel with cutting wheel and cut the resistor board holder in half.
Notice that a small spring has been soldered on the (+) tab
for better battery length flexibility and cushioning.
See below how the resistor got repositioned in the shortened resistor housing?
The excellent stock RYAJ led will be re-used in this case.
A lux3 ***L bin would also work wonders without the need for the resistor at all. /ubbthreads/images/graemlins/wink.gif
Led/resistor assembly reinstalled.
18650 just drops right in like it belonged there the whole time. /ubbthreads/images/graemlins/wink.gif
Litup without the head.
Lit with the head on.
SX1K Q3 on the left at 800ma off the cr123 3 volt battery.
RYAJ on the right at 500 milliamps off of an 1800mah lithium ion 18650. /ubbthreads/images/graemlins/buttrock.gif
