Re: 9v battery and charger recommendation needed
get a duel diversity UHF microphone system that uses AAs , and change it more often, like every 5 hours of actual use.
only question then is how are you going to pay for it
there are some changes from the last time i tried them, but the results are always dismal. or the cell doesnt fit. or the voltage issues
batteryjunction has a good selection of nimh. worth looking at.
ultralast lithiums are said to have some 1200 ma, regulars good alkies have some 550ma and the bestus ni-mhy now have about 250-330 , which is better than the old 180, which was useless, now that doesnt speak of the drain which is important in small cells items.
http://www.powerstream.com/9V-Alkaline-tests.htm
got $5-7 each for ultralast
and some of them didnt do well at all, for some reason, and some did great, but they too are boxy and harder to fit, but at least they do fit. that might get you 2x runtime, many xXx cost more.
i tried the new 400ma li-ion, which i Knew already was a max voltage of 8.4 and it was terrible sized , not to mention that most devices want more voltage than that for sure.
then there is a new Li-Fe-Po which should come out to be a better "match" for the voltage, but more dismal capacity again.
if i was going to try one more rechargable, i think giving the 9.6v 250ma ni-mh would be interesting, just depends competly on the device.
more bad math:
assume for a second that were getting some:
400ma from a alkie, before the voltage is to low and its in the midrange of 8v for its operation, that is some 3.2Watts of power ? isnt it
with a lithium $$$ cell, probably get some 900ma at a midrange of more like 8.5v some 7.6w of power
with the ni-mhy 8.4v type at say 330ma that is 2.8w of power.
SO
why do 9V operational devices suck so much worse than a 2xAA devices , which is say in ni-mh 1900ma x1.2v x2 = 4.6Watts
i am clipping to less digits beings these are totaly rough figures anyways, and trying to stay in the realism bounds.
