Hi guys,
Since these heads aren't really mods or custom and since some of them are headed to Wayne to be made available on the Shoppe as DIY components after they are anodized, I thought this would be the proper place to post them. Both are based on the PR reflector primarily.
One part is a trimmed down or turbo version of the McLux-PR head, the PR-T, for need of a name:
I think the applications for this are relatively straight forward.
The other part is a PR-Can. This head is viable for portable lighting applications but is also intended for transportation and fixed lighting applications. It is designed to receive a Luxeon 1W star and PR reflector by default. It can also host a down boy driver or other PCB that would fit in a .560" diameter by .750" deep cavity behind the star. Certainly other optics can be adapted as well as a bead blasted PR reflector. The driver can be remotely located as in the case of George's cool drivers. Other LED's can be hosted with appropriate adapters or heat sinks. The back end is tapped for 1/8" NPS pipe thread so the head can be attached to a Loc-Line stalk or standard electrical lamp fixture components using 1/8" male threads.
A proto is shown below:
A final note on anodizing: the PR-T's are headed to two anodizing firms. One will do a batch in Black HA and the other will do HA natural. Until these parts are returned and functional in application and fit, this post is a bit premature. At least the eggs aren't all in one basket. /ubbthreads/images/graemlins/smile.gif
The PR-Can's are all going in for black HA finish.
- Don
- Don
