TooManyGizmos
... I'm wondering if this could be possible ?
How about lights made with TWO control buttons to make ALL options available under variable circumstances and needs .... on one light ?
One tactical button on the rear / One variable button on the side - near the front - (like MAG button placement).
For casual use - halfpress the momentary style (forward clicky button) on front/side to start in 1 lumen low - continue holding for ramping upward effect and fully click on when the desired light level is reached.
Or for Tactical use - at ANY time - (which would override the side button) - halfpress the momentary style (forward clicky button) on the REAR to turn it on immediately in maximum brightness (bypassing the side button) or continue pressing till it clicks which would put it in Strobe mode.... - click again to turn off.
This way you could have the customary tactical style button on the end for momentary light - or fully press till it clicks to go into strobe mode. The side button is just for variable light output.
Now this concept might require the circuit to be engineered similar to 3-way light switch's used in homes ... where two switches can control one light .....but is it feasable ..... could it work ?
Could this provide the best of both worlds - in one package
Please provide your opinions
Regards to all ........... TooManyGizmos
