Hi all,
I have a few things I need to clarify for a project that I am doing.
1.Will using a switched PSU get around me needing a power regulator to limit power to the LED's?
2. I want to use a 12v source and approx 12 LED's. I have read that Parallel circuits are not ideal for LED's so I was going to use two series circuits containing 6 LED's each both connecting to the same 12v supply. Assuming the overall load does not go over the PSU's max load, do you see any problems with this?
3. If i did need to use a regulator, such as the lm317, where would if fit in the circuit?
__________________-> RESISTOR->LED->LED->LED->LED->LED->LED->Ground
Source->regulator
4. I have been told if I use a regulator I don't have to worry about voltage. Why is this?
Many thanks from a novice:thinking:
Source->regulator
