I don't know what the "inconsistencies" are that the article mentions, but I will say that I've been disappointed in a number of H4 bulbs I've bought and installed in my 2008 CR-V. The article mentioned a blurry cutoff when using the Philips XtremeVision. I have noted before that I have a pair of Sylvania Xtravisions in H4 at home, and they definitely have a "handedness" to them. That is, if I install bulb A in the driver's side and bulb B in the passenger side, I might get a really wonky cutoff from BOTH lamps. One lamp may have no step to it at all (okay, because it's VOR), but the other one may have a very large step of diffuse light, so there's no real hotspot. But if I switch them and install bulb B in the driver's side and bulb A in the passenger side, both lamps produce a decent cutoff (though it's still not exactly the same).
The same is true of the Philips XtremePower bulbs I have AND the same is true of the Philips VisionPlus bulbs I just recently bought on clearance at Kmart. No, the bulbs aren't burning out that quick, I'm just trying different bulbs to see if any one brand or model is more consistent than the other. And I've found that it's not. For the bulbs I don't have installed, I have a "D" and "P" marked on the packaging, to denote the driver side bulb and passenger side bulb (so I don't have to switch them after installing if I get them wrong).
I suspect that the H4 bulb itself is most prone to this. From what I can tell by looking at the bulb's glare shield and how it's spatially oriented in the lamp housing, that shield has to line up nearly EXACTLY with the "cut lines" on the lamp housing for that functionality to be effective, and for the sharp cutoff to be intact. I've found that the consistency in this respect, even with top-tier bulb manufacturers, is not that great. The only bulbs that have produced two cutoffs that are exactly the same in this car were the OEM HB2 long life bulbs (from Philips).
