?? A P7 in a single 123 light ??
isn't the P7 a 10W led?
That means you have to find a 123 battery that's capable of a 6C discharge, which would give a whopping 10 minutes of runtime.
You could of course run the P7@100mA, but I doubt it would be more efficient than a single P4 at 400mA.
The dies in a P7 are connected in parallel, not series. So you mean "P7 @ 400ma".
I think it would probably be more efficient. If you look at jtr1962's lumen testing thread, the 20ma 5mm LEDs reach peak efficiency at about 25% of their rated current:
http://www.candlepowerforums.com/vb/showthread.php?t=89607
So four underdriven dies may be brighter than a single die at the same current, as long as current level isn't on the left side of the peak efficiency range.
Toshi
Does it exist? Will it? Is it even possible?
I've currently got one running off a R123 & a TriFlupic in the meantime that I finished last night. Will run a 17670 later.
It's not running at it's full potential brightness but it is bright. Gets very hot on high. Strobe hurts my eyes & is very annoying! Runtime is very short with the R123 & the high discharge rate when on high is probably not good for the cell.
As for what host it is in, that's a secret right now. I will post about it soon though. :grin2:
Got one in a Pierce M10/tri-flupic I built a couple weeks ago (totally awesome pocket flood), search for "Micro mega mule". I'd paste a link but can't from an iPhone.
~Chip
Nice! I put a P7 & TriFlupic in an Arc LS with a reflector. It's been my EDC for a few days now. Will post it up soon.
You don't have to run the P7 at 2.8A.
A CR123A will be happy providing 700 mA for an hour. At 700 mA (175 mA per die) the P7 should still put out over 200 lumens. A Fenix P1-CE sized light that can match a TK10 in overall output. (The TK10 will kill the P1-P7 in throw though).
Just swapping a P7 into a P1-Q5 won't work as the the Q5 is not driven that hard (~300 mA) and is still very efficient. I estimate going from 90 lumens to 105 lumens and loosing throw, not worth it.
