csshih
Hey All,
a quick comparison for those who are curious about Thrunite's XP-G Dropin.
I got my hands on this one from jake25 over at the MP.
here's the interesting thread: http://www.cpfmarketplace.com/mp/showthread.php?t=202189
now available at battery junction! http://www.batteryjunction.com/thrunite-p60-r5.html
hm, unlabled box. these are R5 XP-G Dropins
the dropin itself (the brass part) is oddly enough, cylindrical. most dropins are more trapezoid-ish on the bottom
headshot of the Cree XP-G
the thrunite throws better than the 47s Ti quark 123^2 tactical ;)
using the peak function on my luxmeter (extech HD450)
thrunite XP-G dropin 9.37 peak
47 123^2 TI quark 5.35 peak
Lumensfactory D26 LED Dropin 10.53 peak
Dereelight 3SD WG OP 11.28 peak
a runtime with my new meter!
runtime stopped early, but there is a pretty low mode that will go on for quite a bit. when the discharge was stopped, voltage after resting was at 3.2V.
Yes, that hump is real, I tested 3 times (trying to get the meter to load data) with the exact same results every time!
Outdoor Beamshots
compare with other lights here: http://www.candlepowerforums.com/vb/...d.php?t=235171
ThruNite XP-G Dropin (Lumensfactory SP6 host) 1x18650
The ThruNite XP-G Dropin has the cleanest beam profile of all the P60 dropins I own. It also has a very large hotspot (due to the use of the XP-G with its bigger die), which would make it less of a candidate as a thrower. The output and efficiency, though, is no slouch. This is currently my favorite dropin... one of the brightest and most efficient dropins you can get without venturing into the MC-E dropins, which will have a donut hole in the beam, and get very hot very quickly.
Outdoor Beamshots
