I'm hoping someone here can provide some insight.
I have had custom made LED potlights + an entire deck powered by multiple groups of LEDs (4 diodes in series) running at 85 mA (with proper selected resistors) while the LED meant for 100mA... so this accounted for me not running a constant current (15V) power supply.
This was fine for months with no problems what so ever!!!
My father decided to install a water-sprinkler system to control our power supplies for the LED's with daily schedules and install a relay which separates the LED groups from the power supply.
This was running for about a week.
After a large thunderstorm last night we noticed that both the outside potlights and the deck has LEDs that are not working (30% stopped working) but they are not burned because the rest of the LEDs that are connected in series with it are working... its just 99% dim. - those that have not been affected are still 100% just as bright.
I cant rule out a few possibilities.
They all stopped working in one day so it couldn't be a gradual shock of the power supply.
The relay separates the power supply from the LEDs so...
Could the wiring act like an antenna for the static...
Could the powersupply deliver a shock after being charged once the relay let it connect with the LEDs through the water sprinkler system.
Power Surge?
I am so clueless, because the LEDs are not burned.
Another group of LEDs which are lighting trees (through a different power supply and not connected to the relay-watersprinkler system) is working 100%. I know its grounded because they directly touch ground but also how come the thunderstorm (if its the case) did not affect those but affected those LEDs connected to the relay. (Probably no powersupply directly connected to ground them?)
I cant rule out any possibilities.
Does anyone has any expert advice on how to protect these sensitive LEDs from environmental/ other types of damages and also what the reason for all these LEDs to stop working all at once?
Power Surge?
