DigitalGreaseMonkey
- Joined
- Sep 7, 2008
- Messages
- 122
About a week ago I was loading 18650s into the chargers when I fumbled one. It dropped about six inches, the protection circuit landed on a hard plastic corner of one of the chargers. Sure enough, that was all it took. We all know how forces get magnified when concentrated in a small spot, so I was not surprised.
These were new Trustfire gray cells, 2400 mah. I am liking these cells very much, so am reluctant to send this off to recycling heaven. I got curious and removed the plastic wrap. I carefully lifted up the protection circuit to get some slack and cut the connection to the positive end. I was able to fully remove those ribbon connections and now I have an un-protected cell.
The white plastic ring that fits around the button top is adhesive and went back on. There is still a thin layer of plastic around the case, except for the end.
The volt meter shows 4.20 volts, and the ZTS pulse load tester shows 100% capacity.
For the more experienced folks out there: Are there any concerns or surprise issues I should worry about if I use this cell with my other un-protected cells?
The other un-protected cells, which came "free" with one of my Solarforce lights, are also 2400 mah rated and I suspect they came from the same factory. They just happen to be Solarforce branded. The reason I suspect a common heritage is because of the shape and tooling marks on the button top. (I understand that it is possible that the case components may be sourced to many different companies.)
Any thoughts?
Best regards,
DGM
Any thoughts?
Best regards,
DGM
