Vbeez said:Guys, how to make home made AA battery discharger that stops at 0.9 volt ?
I'm trying to recondition some NiMH AA batts. Thanks
Doug S said:Simplest would be to discharge through a resistor in series with an ordinary diode. This will take it all the way down to around 0.6-0.7V but this is just as good, if not better, for your intended purpose.
I've tried that before, didn't work for me. Don't you thing 0.7 volt is too low ?Doug S said:Simplest would be to discharge through a resistor in series with an ordinary diode. This will take it all the way down to around 0.6-0.7V but this is just as good, if not better, for your intended purpose.
