- Joined
- Nov 19, 2017
- Messages
- 245
I am looking for a single AA light that is either one high mode or starts on high. I need it to have a clicky tail switch. Must be alkaline compatible. NIMH and 14500 would be a plus.
A truly underrated light. I love mine.Streamlight 1L-1AA, can be ten tapped to come on high only.
"start on chosen output level (of 4)"I use a couple of Eagtac D25A MKIIs quite a bit. They run great on AA, although I often use secondaries (14500) in them (both are 'supported'). They can be easily (without reading a manual for an hour) set to 'max' only, or to start on chosen output level (of 4). They're available from a great U.S. distributor (although that might be the other side of the world from you) for ~$50 USD shipped fast with a choice of 5+ different emitters (my favorite is the SST-20 4000K). I find them very usable / useful. Just one for your list to check out.
Streamlight looks good. Does anyone know the max voltage? I'd imagine the NIMH rechargeable is fine. I'm thinking maybe a 14500 is too much.Streamlight 1L-1AA, can be ten tapped to come on high only.
Right up my alley. I have the MDC TAC. I did discover I can put the TAC head and run it on a single AA, but I haven't tested how long it will last yet. I only want the AA because I always have them available at work. I wish Malkoff would come out with SHO AA or TAC AA. I use my Malkoff AA all the time at home at night, but have to cycle through to get to high to make it suit my needs at work. I use my light a lot at work.I know this isn’t AA, and I don’t know the environment you’re using this light…but if it’s based on security concerns and you need an AA size, here’s a super high quality option that will always work year after year:
MDC HA SHO 1CR123 Flashlight – Malkoff Devices
Hard Anodized Black MDC (Malkoff Daily Carry) 1CR123 Single Mode High Only Flashlight. The Output is 320 Lumens. The runtime on one CR123 battery is approximately 45-60 minutes. Dimensions: Length: 3.75 inches Diameter: 1 inch (largest diameter of head) This Flashlight was designed for rugged...malkoffdevices.com
I think 3.6V li-ions drive it a little too hard, you might get away with using them for a while, but they are overdriving the LED. I have used 3.2V LFP cells with no issues, but that's as far as I would go on a regular basis.Streamlight looks good. Does anyone know the max voltage? I'd imagine the NIMH rechargeable is fine. I'm thinking maybe a 14500 is too much.
as a work light it’ll be hard to beat that convoy T3. As long as you like one of the colors then you’ll really like the T3.I use my light a lot at work.
Definitely an option. Thicker and heavier than the MDC, and I think it is about 80 lumens or so?I believe my MDC TAC head gives about the same result and is smaller.If you like the MDC AA except for the mode switching, what about an MDC AA body with a VME head and M31 drop-in of some flavor? (The M31LL is probably the most that will stay in regulation on a single AA, though)
Ironically, the literature that comes with the light says not to use rechargeables of any type. I wouldn't risk using RCR123s nor 14500s in mine. I'm sure other CPFers who own an SL 1L-1AA have used MiMHs. I just personally haven't either.Mine's fairly new and I haven't run NiMH in it yet (only LFP123 / CR123A), but 14500 (3.6/7V) Li Ion is not supported AFAIK, and its use would risk failure.
