I have a 3 D cell flashlight modified for square wave output, not that it matters, just needs fat D cells, posted FYI.
Recharging D, buying them, the expense, the singular use of the Ds over the AAs, is a pain. I rather bulk buy AAs for price breaks.
If you get a D cell adapter, to house AAs, lets say for argument, you buy the same mAh as the Ds, is it the same?
Don't Ds have more material, volume, within the same mAH rating of AAs, so this would imply more storage? Or is it moot, mAh is the same no matter what volume the cell, i.e same run time?
The D adapter I am looking at can house 1,2,3 AAs.
Clearly this is an advantage, sharing the mAh load over multiple cells? So that would be a huge plus, especially using the circuit that is producing the square wave has a sharp voltage cutoff. You get a warning of low voltage, but you need a certain voltage to drive the circuit, no fading of light, just cuts off.
Many thanks.
Many thanks.
