The title has what I am primarily looking for. I copied the form from the sticky and deleted sections that were not applicable in my opinion.
AstroLux A01 AAA is a very close fit but does not have a clip to attach the light to a hat brim. Primary use would be backpacking. Lightweight is preferred as well, so no brass and such.
1) How would you prefer to purchase the light? online or in person rather buy in US but would consider overseas shipment
2) Budget: An easy question, but you may change your mind after answering the rest!
____Up to $25. maybe optimistic but have to start somewhere
3) Format:
single AAA cell flashlight with clip to attach to hat brim for use as a headlamp
4) Size:
see 3
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness) neutral white type like nichia 219B
6) Manufacturer:
someone else makes it and I buy it.
_x___I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA sized cells common to most stores.
_x___I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA sized cells common to most stores (often a cold weather or long storage choice).
_x___I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA sized cells common to most stores.
___x_I want a fire fly mode (0.01-0.5 lumens). ~ 4 days run time would be nice, more if possible
__x__I want an indoor "blackout" light (20 - 40 lumens) 5 hours or so runtime goal
__x__I want to confidently walk around an unlit/unpaved rural area (60 - 90 lumens). don't expect more than an hour here.
somewhere in here
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__x__Less than 1 yard/meter (reading, other close work)
__x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__x__5-20 yards/meters (check out a noise in the backyard)
____
firefly - 3 or 4 days hopefully
medium 3 - 5 hours, more time and lighter end of scale is preferred
high - 30 min to an hour
_x___Very Important (Camping, Backpacking, Car Glove-box).
__x__Any size switch commensurate with a AAA light will do.
See above
14)Material/Finish/Coating
commensurate with above
15) Water resistance
__x__IPX7 (Waterproof to 1 meter/30min) preferred but not a deal breaker
16) Storage conditions
____In house (temperature/climate controlled environment)
____Neutral white emitter like Nichia 219 type
3) Format:
4) Size:
see 3
6) Manufacturer:
somewhere in here
____
See above
