AAA Lights with warm tint?
sol-leks
I was thinking about upgrading my keychain edc and was curious as to whether or not their are any warm tint options and if so what are they?
A lot of people means what CREE calls neutral white when they say warm white. If neutral white is OK, Liteflux LF2XT is a very good choice.
You're absolutely right, thats what I meant. Thank you.
The LF2xt looks very nice, but I'm not sure how I feel about keeping a light with a clicky in my pocket. Ideally, this light would go on my keychain.
Investigate and read threads about the new - ITP A3 EOS and the Maratac AAA
Single mode and also triple mode.
Very nice and inexpensive.
The LF2XT has the warmest tint of any of my lights. If you're concerned about the light being accidentally turned on while on the keychain don't worry. There's a three minute auto-shutdown option.
Geoff
You can get a neutral tint rebel in the Peak Eiger. Single mode twisty is as simple as it gets for the pocket. You can pick beam profile and which brightness level you want when ordering it.
TMG did I miss something with the Maratac/ITP Eos? I didn't think a neutral tinted emitter was available stock?
No you didn't miss anything just someone commenting without reading the thread. Although that light is very nice and attractively priced.
I will def check out the peak eiger.
It seems like they have been making an effort to make all the quark lights have neutral options, too bad they haven't done a AAA quark light. That isn't in the works is it?
Sorry .... baterija is right ..... it's not a warm tint.
Thought I saw some comments about it being creamy ?
Please ignore it then.
It is nice,tiny and bright tho.
You could always get one of the current lights modded.
I'l be modding a couple L0Ds when I get around to it...
:naughty:
Sounds awesome, Im carrying a plain LOD at the moment.
I generally lock out my LF2XT in my pocket; also in case I forget I have it set to come on at the lowest output level, which is very low, similar to the quark moon mode.
If you use the auto shut off feature, you can't use the over discharge protection; so you have to choose one; I chose over discharge.
AAA Eiger #6 or #8 warm or cool tint- Wide, Medim or Narrow optic choice- Brass, SS, or HA. The 10440 ultrafires make these scream- I was running Eneloops in them and they work great, as do L91 cells and plain old alkalines- but the 3.7 v Li-Ion- wow.:cool:
I think they are Rebel 0100.
