AAAA, AAA, AA, C, D, . . . . So where's A and B?
Orion
Bronze Member
Missouri
AAAA, AAA, AA, C, D, . . . . So where\'s A and B?
Did they just not make it in the industry? /ubbthreads/images/graemlins/blush.gif
Re: AAAA, AAA, AA, C, D, . . . . So where\'s A and B?
I asked this question before and I don't remember the specifics, but I think both of those sizes were made at some point, but just didn't become common. I think it is still possible to find A's in some very rare and specialized uses.
Frankly, I am glad. It seems like we have too many battery sizes anyway. Standardization is a good thing.
A sized rechargeable batteries are quite common. Also, the "A" on the end of "CR123A" refers--I assume--to the diameter, which is the same as an A sized battery.
Don't know about the B sizes, though. I haven't seen any for sale nor have I seen any references to them. Perhaps that was skipped because they were using "B" for "Battery", or perhaps it used to be a size and died out. No idea.
They used to make size A and B batteries for use in vaccume tube radio sets.
Radio A batteries were low voltage (+1.5 volts typical) at high current, and were used to run the tube filaments.
Radio B batteries were high voltage (+22.5 to at least +90.0 volts) at low current (one such +90V battery was made from ten 9V transistor radio batteries connected in series), supplying the plates of the tubes with high voltage.
Leave it to The LED Museum to have the answer. /ubbthreads/images/graemlins/wink.gif
I read that B-sized batteries were 43V or something like that. And the high voltage was necessary for powering tubes. Didn't draw a lot of current though. B was replaced by the 9V because transistors took over tubes and required less voltage to operate.
I think you will still find A-sized cells in a lot of rechargeable toothbrushes, but I don't think there is a call for A-sized primary cells anymore.
I understand that there is an F battery and this is commonly known as the 6V lantern battery?
Was there ever an E battery? Are there any other designations?
Steelwolf, yes there were E batteries, can't remember what they were used for but can remember several large "E" cells at my uncles farm in South Carolina in the shed. i can't remember voltage or any specs.
The F cell as 6V lantern makes sense, the E cells were more square, and if I remember, shorter.
Lots of "A" cells still in use in Remote Control planes, robots, etc. The are available in both NiCad and NiMH configurations, as are variants like 4/5 A's (shorter), 5/4 A's (slightly longer) and 4/3 A's (suppossedly longer still, but most of the spec sheets show them the same as 4/3 A's)
The various prototypes of the Mule have used 4/5 A's and 4/3 A's.
Bill
Bill
I believe a 6v lantern battery is made of 4 F cells.
some 6 volt lantern batterys are made with f cels
some are made with d cells
bernhard
[ QUOTE ]
[/ QUOTE ]
Craig: In the context of vacuum radio set batteries, A and B did not designate sizes. They designated functions. The A batteries powered the tube filaments, the B batteries provided the high voltage for the cathode to anode circuit. There was also a "C" battery function which served to bias the grid voltage of the tubes.
I have some Eveready 'B' size batteries (now obsolete) that are 4.5v low current if I recall correctly. These were to power some meter and I also have an old VOM that has a place for these in the beeper for continuity testing...
I remember bringing these up on CPF several months ago. A search would bring you some more information including a link to the Eveready info.
Doug S is right on. IIRC, the "C" battery was the highest voltage, and therefore the first to be engineered out of the equation, either through new parts needing less voltage, or a transformer. So when the dry cells standardized, no one thought twice about having a C-size battery, but the A and B might be confusing to radio applications.
Pic of B-cell: http://www.bitwaste.com/wasted-bits/archives/000115.html
More info here: http://www.angelfire.com/ma2/AdamVon/tobatt.html
[ QUOTE ]
[/ QUOTE ]
No. The "C" bias batteries where generally less than 10V. It was the "B" batteries that ranged up to 135V. For B batteries the most common values were 45V, 67.5V and 90V. These voltages based on 1.5V times the number of cells in the battery.
As Bill stated above, the 'A' family is widely used, I new the CR123 cells first as 2/3A before I heard the term '123'.
The most common Li-Ion cell is the so called fat 4/3A, known as 18650.
And we know the sub-c (Cs) as used in power tools, the most common high current cell (may change soon).
The F cell is actually a 3/2 D.
Funny enough, all these 'names' are obsolete, as there is a another scheme to replace it, but nobody cares.
