Accupower Evolution C 4500mAh low self discharge....
ODatsBright
Cambridge, MD
I recently purchased some of the above cells and I've run some tests on them and I'm very happy so far.
After the first charge cycle they tested at over 100% of the rated capacity and within 2% of each other.
As soon as I have some run time curves I'll post them here...
I use mine with a P7, output is outstanding. The LSD works too. I've had them a year and still haven't charged them - even once...
Maybe they're more capacity than you need? :thinking:
Did you ever try 2000mAh AA LSDs with 'C' Adapters?
From my extensive reading of SilverFox's missives, *ALL* of the chemicals need to be exercised on a somewhat regular (~3-6 month) basis or you'll lose capacity.
Good suggestion, but its a question of use. I put it together as a 'best use' P7 for a rare pewter 3C Mag and these were the best cells for that emitter/config. But I find that I prefer smaller lights (6P etc) for LEDs and I just don't use it beyond showing off. My black 3C with and IMR powered 1185 keeps stealing the spot light. :rolleyes:
