Acebeam X45 XHP 70.2 owners, User interface question
DayofReckoning
USA
I have an Acebeam X45 70.2 5000K, and I think there may be an issue with the UI. With the Firefly mode engaged, holding the button for the next mode, the light skips over the low mode and goes straight to mid mode.
Is this normal behavior?
I think it's jumping to the mode it has memorized when you last had it on. Can you go to another output level, have it memorize it, and try the test again?
UGHHH! These silly UI's! Wasn't till I read your suggestion, then wrote down my results did it make any sense. That's exactly what's happening. :)
The build quality and output on these Chinese lights is getting pretty amazing, if they would only do away with these complicated UI's :scowl:
