Do you make any lens kits for D mag lights? I think it's 52mm. I'd love a lens kit for my modded X-ML 2d mag!!!
I can only supply the (lens+spacers+brass pill+LED+driver) = dropin.
1.4A is brighter but generates more heat, eats more energy and is beyond the manufacturer spec.
One-mode only.
I won't glue the spacer on so you can adjust it as you like.
No problem.
The kit is normally $55 and I mentioned an extra $25 for the dropin, but $80 seems like too much. So I'll make it $70 instead (including postage).
Extra note: I suggest only using 18650s in your L2P. Using two CR123s will not be good for the driver. Also it will have a much shorter runtime.
the brass part (pill) screws into the black spacer u get from Ahorton
that goes into the body of the light- u screw the head back on
then u remove the bezel n lens and drop the aspheric in and replace the bezel
I use 2400mAh cells in my lights and get about 90-120 (depending on the particular LED) minutes at full brightness and then starts dropping down. As it drops down to a lower power level it usually lasts a few more hours (say 2-4) but it's not so much fun so I charge it up again. I prefer the semi-regulation that gives me a few more hours of light just incase I really need it in an emergency. I think this is better than having it go a full 2 hours and then stop suddenly (full regulation).
I'm going to buy a few of these lenses. Anyone interested in a US group buy? I'll purchase, repackage, and resend for cost + $8.00. Most likely that would amount to $8.00 or $10.00 per lens plus $8.00 per order. Prepaid through Paypal.
