Aleph 1.5x123 Tube
Ray,
With the tension of the contact spring against the batteries, I didn't get any rattle from them.
I haven't tried it myself, but it stands to reason that if a 3X123 body will take 2 AA cells, the 1.5 should accept 1 AA. There might be some battery rattle though, due to the less diameter of the AA cell.
Just tried it and it holds 1xAA but will rattle with the McE2S set-up and eventually have inconstant electrical contact. With a Z57 no rattle and perfect contact.
bernhard
P.S:: dito to tyler!
[ QUOTE ]
this_is_nascar said:
In a couple posts, I've read this tube caccept 2xCR2 cells to allow various 6-volt configurations. Has anyone tried this setup? Do the cells fit without rattle?
[/ QUOTE ]
I just received my 1.5x123 tube from Wayne today. Attached to an A-3 with DB917-Lux III, this sucker works nicely. I haven't (and don't intend to) done any runtime tests, but it's great if all you have lying around are CR2 cells. It also decreases the overall length by a good half-inch or so eyeballing it.
Ray, I am using 2 x CR2 in this one ... no Li-Ion for me. Works flawlessly, but I dodn't do a runtime test, don't have that many of those cells.
If you are interested I can do an apporximate runtime on request.
bernhard
Ray or Bernhard,
Which CR2 cells are you using? Do you happen to know the voltage and maH ratings of the cr2 cells?
I think batterystation sells cr2 sells for 1.25 each so I may decide to use these instead of 2x123 on a BB750 Lux V head if the numbers seem to work out fine for voltage and current.
Thanks.
Curtis
I have Sanyos because they were cheap, and I am in no position to comment on CR2 cells ... barely use them at all exept for funny lights like the above pictured and ... /ubbthreads/images/graemlins/cool.gif Larry's Cr2 II ...
bernhard
Keissling,
How did you get the Lux V in that L1 head? Is it LE compatible? I just did an L1 head mod and had to practically jump through hoops to make it LE compatible. I did it, but it wasn't easy.
Sorry, off topic.
Tony,
Customized ES-Can and they are a PITA!! I used a bored out ArcLS retaining ring as a centering jig for the can and I pot the mess in the head. At least that's what I recall. /ubbthreads/images/graemlins/icon3.gif I remember enough that I don't plan to revisit the mod! /ubbthreads/images/graemlins/tongue.gif
Don,
You're gonna laugh. I cranked out a delrin plug for the front to protect the front 1/4" of the inside of the bezel. I then coated the face of the plug going into the light with grease. I then filled the head up to the threads with JB Weld. I let it sit for a while and got tired of waiting so I cooked it at about 150 for 10 minutes and the JB got rock hard. I then drilled out the JB with a 3/4 bit and chased the threads right into the JB Weld. Man, that stuff is tough. Anyway, voila. I dropped a reflector in it and it was good to go. It took about an hour to do and was pretty easy once I figured it out. The JB Weld is almost like steel once it hardens, but at this point, only time will tell.
I've gotta admit, it's a cool looking light. If the heads were more available, I might do a few more.
BTW, have I mentioned that I really LOVE the McR20s!
Ah Don ... I just wanted to tell Tony how hard I worked to put the LuxV in the L1 head ...
Dito ... the McR-20 is one of the coolest little masterpieces available to date!
But in this head there is a so17xa as it predates the Aleph-Series by a few months. Gives a nice and perfect flood.
bernhard
