Alternative .pdf readers?
geepondy
Massachusetts
It's bad enough windows updates itself so regularly, I really wonder if a program, simply to read .pdf files has to do same as Adobe reader does. Do you guys use an alternative .pdf reader? If so which one, I know there is a few.
Many people use Foxit, which is free and open source. Download here.
Sumatra is also free and open source, homepage here.
I've used both, and I like Foxit more. It's small (compared to Adobe reader) and fast. Hope that helps.
Windows update can be shut-off in control panel. Although to Microsoft's credit, it's among the least intrusive apps that do this.
Adobe Updater however can be annoying as hell. You need an afternoon to install any of Adobe's slightly older suites and patch them up.
I use Okular, but I don't recall if that's been ported to windows yet.
I'm using Linux, so I tend to forget sometimes how much of a hassle windows updates can be :poke:
foxit is much faster than adobe...which is an resource hog of its own:thumbsup:
plus the pdf opens as a tab in firebox, not strewn all over the place on the taskbar
When I was hopping around doing contract network admim work for the local banks not so many years ago we got about 2x as many critical security alerts for *Nix as Windows. Secondary patching however is far less a problem with *Nix because unlike Microsoft the Open Source crowd does know how to communicate, and when they patch, they typically get it right the first time.
For the record, Windows systems typically get hammered with user level security alerts that are typically negated by proper control of local administration rights. However, the Linux crowd are a flaming bunch of hypocrites in this respect because they push for /root restrictions on Linux while not comprehending that the corollary on Windows accomplishes much in the same.
Am I understanding correctly that Firefox and other Windows browsers need special extensions or third party applications in order to view a PDF inside the browser? :faint:
PDF is an open standard. Why isn't the support native? I guess I've always just taken it for granted that I can click on a PDF link and it opens up normally, like any other web page. Wow. I thought that capability was ubiquitous.
The evolution of the Adobe Reader reminds me of what happened to AOL Instant Messenger -- a simple utility that transformed into Bloatasaurus rex over several version upgrades.
most file formats need a plugin to incorporate them into webpages as browsers are not designed to handle their file formats.
I use a combination of Sumatra PDF and Foxit since they're both good at different tasks.
I prefer Foxit over Adobe or Sumatra as a normal PDF reader but the reason I use Sumatra PDF as well is because I make PDFs in LaTeX with TeXnicCenter. The latest Sumatra integrates with TeXnicCenter and automatically refreshes the PDF whenever you change the document. With Foxit, you have to manually close the document and re-open it to see your changes. If I'm also viewing other papers at the same time, I can't just close Foxit, I have to close the particular tab of the document I'm working on, switch back to TeXnicCenter and press F5 to make it reload the document. Pain in the ***.
Foxit's a good replacement for Adobe Reader, but because it also has a lot of the same interactive functionality as Adobe, it is also vulnerable to the some of the same recent exploits as Adobe. To their credit, I believe Foxit has fixed these. Still, if you're switching to it for improved security, just realize that no software is invulnerable to exploits.
Have you ever used Gentoo? It was the first Linux I tried and I couldn't stand that updates could take hours or even days because it has to compile everything.
Problem is that a lot of Windows software was designed with the assumption that the user is always running with administrator privileges, which means that it was inconvenient at best to run as a limited user. It's getting better; the only software I have that needs admin rights is my DVD burning application. I'd love to have a su / sudo in Windows though.
I prefer my own choice for a PDF viewer, not what the OS or browser decided for me. I imagine that on Macs the browser hooks into Preview to show PDFs. Since Windows doesn't come with Preview, you just need to install other software that the browser can hook into, so it ends up working in a similar manner. There's also the issue of whether Adobe would try to sue Microsoft if they included a PDF viewer for abuse of monopoly, in the same way that Netscape did in response to Internet Explorer.
I have many PDF viewers available to choose from. Conveniently, the native one is the one I prefer (after trying out a few).
Adobe Reader is a resource hog full or massive security holes.
Foxit is going to be one of the best choices, for your patience and your security.
