Bushman5
- Joined
- Sep 8, 2007
- Messages
- 977
tonight i took one ammo can (6" wide x 10" tall x 12" long), and mounted a angle bracket on the front. This will eventually hold a PIAA or HELLA 12" wide pencil beam lamp and housing assembly (H3 form factor) right now it has a 100 watt Hella pencil beam lamp on it. PIAA makes a 160 watt UltraWhite lamp assembly that i'll eventually drop in.
for power i have 12V 15AH SLA.
wiring: I used 10 gauge copper strand wire, silversoldered, crimped and heat shrinked connectors. The switch on top of the ammo can (by the handle), is a milspec grade metal toggle, rated for 600 amps , 240 volts. SPST.
its not a barnburner or maxablaster, but for a inexpensive searchlamp its pretty damn bright. It lights up houses over 3 blocks away .
will have pics soon.
