georges80
In a fit of boredom I decided to build a few prototypes of a driver that will be well suited for multiple Lux 3's or Lux5's. I was running some other prototypes & knocked together the Fatman schematic and layed it out onto a portion of the PCB panel.
Here is the first Fatman prototype just before firing it up. And, since it worked (just minutes ago) I figured I'd announce a few specs and see what the interest is in running a production board.
Some basic specs:
[*]0.8" diameter
[*]boost converter
[*]nominal 600KHz switching frequency
[*]center rear nubbin (Vin) rest is ground plane to the edge
[*] adjustable via onboard trimmer (for configuring)
[*] Vin (min) = 2.7V, Vin (max) 12V
[*] Vout (max) = 16V
[*] Fully current regulated and fully adjustable either on board or via external pot (in parallel with trimmer)
I did some very preliminary testing and measured over 90% running from 3.30V - 5.0V while driving 720mA into a 5W luxeon with a measured Vf of 6.46V. The current output was just where the trimmer pot happened to be set to.
This switcher IC has a 2.55Amp (minimum) switch current limit so is well suited to higher current outputs. Fatman would be well suited to driving 3 Luxeon 3's (series connected) at 1A from say 3 123 cells for example.
Remember, the driver is fully dimmable and is configured to put out around 30mA at the fully dim setting.
Anyhow, much more to come as I get time to take more measurements and in response to any question you guys come up with. I also need to characterize the driver over voltage range and loads (lots of stuff still to do).
Right now things look good, but until I do the rest of the measurements and tests...
george.
Some basic specs:
[*]0.8" diameter
[*]boost converter
george.
